Well as some fo you may know I succesfully got my 7MGE-T running. I'm using the NA block and head with all the turbo electronics and turbo stuff. The car runs good, but when I'm driving and I'm under boost right around 4700rpm the car stumbles. It almost feels like fuel cut, but I know it's not. I'm only boosting at 10psi.
I am getting code 34, which leads me to believe I have a boost leak. Would that make the car stumble under boost?
Also I have no gauge lights. When I turn the lights on I hear a click and then nothing. I also have no turn signals. I did replace my stock temp and boost gauges with aftermarket ones. I did read in one of Jdub's posts about how you need the boost gauge drive circuit box to complete the circut so I jumped it how he had shown in the post and still nothing. All my fuses check out fine as well.
I have all the dash warning lights, my tach and speedo work great. When the car is urned on and my climate control lights up but when I go to turn the light on it goes away but the glove box light still comes on when i turn the lights on. Could this be something to do with my dimmer switch?
Any help would be greatly appreciated. I wold really like to get these things worked out so I can get it back on the road.
