stumbling issues
buzzbomber
buzzbomber performance
ok guys i have an 89 n/a 5spd only mods is exhaust and intake.
problem arrizes only when the engine is warmed to temp after driving for a while and when it reaches that no matter what speed i'm at or gear it starts to surge and buck like its throwing the tps into a wierd loop with a/f mixture and making it flood. not sure whats up. no matter what i do with the throttle it still does it. i can shut the key all the way off while coasting or stopped and start the car and put it in gear and it runs fine for a few min. and then does it again. car runs great until it warms up. my thoughts are that its the o2 sensor but what do you guys think?
AJ'S 88NA
2,419
Florida
Sounds like maybe the ISC. Have you checked for codes? Or CSI stuck.
AJ'S 88NA
2,419
Florida
I think if the CSI isn't working right it could keep adding extra fuel after warm up causing it to run rich and stumble. And like I said and cuel said check for codes.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
The Cold Start Injector is ONLY powered when the key is at ST1 (while you're actively cranking the engine). After that, if it's adding fuel, it's outright leaking. http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=038
What you're describing sounds like what my AFM was doing when it died. There was a break in a circuit which didn't sever the trace until the AFM heated and parts expanded. I only managed to find it without a doubt by testing the pins while constantly heating the AFM with a hair dryer... after a certain temp, nada. Heh, I got a lot of funny looks on here and SF about that... but it worked.
Other possibilities are:
the ECU's coolant temp sensor
knock sensor or wiring
TPS
AFM or harness wiring specifically to the FC switch
You have any error codes?
