well getting the camera the fotage is on is showing to be a pain in the arse, while. i figured i'll post a mod list for those who care.
-FMIC
-2.5inch i/c pipes w/ 4ply cuplers and t-bolts
-3inch straight exhaust
-R154
-fidanza Flywheel.
-6puck ceramic disk w/ stock pressure plate
-Griffin Aluminum Rad.
-lc-1
-maft pro w/ 3bar map in speed density.
-aeromotive fuel presure regulator w/ SS braided lines.
-Walbro
-n/a cams
-Titian cam gears
-titian 2mm Mhg.
-Arp, head and main studs.
-Arp Rod bolts.
-Balenced and polished rod's.
-oem pistons 20 over.
-knife edged, and lightened crank.
-balenced and blue printed motor.
-5mg shimmed pump,shimmed about 3 mm i think next time i'll do 5mm
-new toyota crush sleeve and cross over tube for oil pump.
-Coil pack relocation
-All new bearins, seals,belts and gaskets when motor was rebuilt 6k ago.
-Ct57GT from supra mania GB, just an upgraded stock turbo.
-n/a valve covers
if, i forgot any thing i'll just update the list
__________________
i'll also be porting the waste gate soon after i hit 4k it spikes to 19.:1zhelp:
-FMIC
-R154
-fidanza Flywheel.
-lc-1
-Walbro
-n/a cams
-Titian cam gears
-titian 2mm Mhg.
-Arp Rod bolts.
-n/a valve covers
__________________
