strut bar/ coilover help!!!
a70Derek
Clean& Simple.
Apr 15, 2007
148
$an Diego
i was going to put my strut bar back on, and i bolt was too tight so i kept pushing and i stripped it
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
I've never stripped a nut on a bolt before (this is what you are referring to right?), but I've broken bolts off before that had to be drilled out, this one doesn't apply to you I think...
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
If it's a nut, try to get a crow bar, flat head screw driver or something, under the nut on opposite sides (will most like take a friend) and start loosening the nut while they GENTLY start prying up with it. hopefully the nut will jump the stripped thread and come on out...
a70Derek
Clean& Simple.
Apr 15, 2007
148
$an Diego
okay so i tried cutting the nut off but the parts are still there& im screwed.
i didnt mess up the thread on the bolt , but it's the nut thats not coming off.
a70Derek
Clean& Simple.
Apr 15, 2007
148
$an Diego
here are the pics
a70Derek
Clean& Simple.
Apr 15, 2007
148
$an Diego
BorHor said:
wow how in the hell did you do that. cut down one side then get a screw driver to split it off.
yea that nut is stuck there i tried cutting it and prying it out but it didnt workk.
any ideas?
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Once you are getting close to cutting through and into the threads of the stud, get a hammer and flathead screwdriver (or use your imagination with another tool) and put it into the spot you were cutting into, angle it to where it's almost horizontal, and hammer it, should help break the nut in half.
Guyana00
Droppin that JZ in soon!
Apr 18, 2007
1,208
Brampton, ON
Damn bro u stripped that nut up real bad. I hope you get the idea and know not to let it get that bad next time.
Make sure you use the right size socket always and use some WD-40 or something similar if the bolt is tight or kind of seized. Also, once you see it starting to get stripped like that, do not continue. Use a vice grip like suggested before and crack it, once it's cracked use the socket and you're home free.
Right now with the nut already cut and abused like it is in the pics, you're probably gonna have to cut it off like also suggested.
P.S. Using the screwdriver to break the nut is a good idea, but I suggest also trying a chizzle, the bevelled edge and thicker shaft might make it easier to break.
Good luck!
-Shankar
TobyCat
470
Vancouver BC
holy crap, how did that happen!? You are loosening it right? (righty tighty, lefty loosey)
Once you get those off though, you'll have to restud your cuscos.
