stroker kit
Status
Not open for further replies.
suprarich
Guest
Nov 9, 2005
2,187
ohio
Yes there is, just do a search for 7mgte stroker kit in your search bar of your computer and I know it will pull up one. I am also working on developing a stroker kit for the 7mgte. Just need more time and money.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
is any one going to make a ture good stroker kit like come on they make em for ever other freaking car
supradan22
NA->TER
May 20, 2005
915
ORLANDO FL
Meh....never mind then I think it was HKS that destroked the 7m to a 2.8 and the spun it to 9 grand someone correct me if im wrong I know it ran like 9's on a tube frame.
figgie
Twin Cities, Minnesot-ah
let me rephrase
the 101mm stroke can be reved high. But everything needs to be PERFECT AND only a standalone will be able to accomplish that with any sort of reliability.
If I recall Defiant_7M was reving his to 8k.
Suprapowaz!(2)
2,870
San Antonio, Tx.
Our engines are already oversquared as it is. I wouldn't want to stroke my 7m. Now how in the heck did HKS manage to destroke their 7m? Custom crank? Is there any kind of stock crank we could use to destroke the 7m? I would like a more square or undersquared motor. Anybody?
supra90turbo
shaeff is FTMFW!
32
MA, 01440
I doubt Allan's car is running... he's got a lot of plumbing to do with that dry sump tank, not to mention placement of the tank itself... yeesh.
If anything, I'd destroke a 7M to make it closer to square.
SP!(2): IIRC, 5M crank and Rods should do the trick...
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
i was thinking the same thing for destrokin...
altho i have always just thought about etting a 5m block and swaping the 7m head onto it.
figgie
hmm
let me say one thing to end this little arguemtn.
Oversquare overshamer... don't mean dick if the engine is balanced properly.
For evidence see the 3.4L 2jz stroker kits. They are only 3mm shorter than the 7m stroker at 94mm (97.5mm for the 7m) and they are reving them to 9.5k rpm ;)
suprarich
Guest
Nov 9, 2005
2,187
ohio
figgie said:
hmm
Figgie is correct on this all the way. I had a Harley that was 3.5" bore and 5.5" Stroke and would rev to 8k. It is all about Balance
Status
