Stroker kit
juggy61
46
Sheridan
Im sure many of you have seen the stroker kit from flatlander racing, my question is if you increase the stroke of an engine does that lower the rpm you can safely run? If say you increased the stroke on the 7m, will you have to lower the rpm limit lower than stock?
Dirgle
Conjurer of Boost
Pauma Valley, CA
This post by Supracentral does a pretty good of answering your question.
http://www.supramania.com/forums/showpost.php?p=180719&postcount=18
Bits and peaces taken from the post:
Supracentral said:
The industry "rules of thumb" for mean piston speed are:
Under 3,500 ft/min = Good reliability
3,500-4,000 ft/min = Stressful, needs good design
Over 4,000 ft/min = Very short life
Determining the mean piston speed is damned simple.
Stroke and RPM are really all you need to know.
The formula is Cm = 0.167 x L x N
Cm = mean piston speed in ft/min
L = stroke in inches
N = crankshaft speed in rpm
Take the stock 7M-GTE with a 3.582" stroke and a 6500 redline.
At 6500 RPM your stock motor has a Mean Piston Speed of 3880 ft/min. Based upon our chart above, you are already "pushing" it in stock trim.
So now go back to our 7M-GTE and let's throw the Flatlander stroker kit into the mix.
The Flatlander kit has a 3.833" stroke!!! That's HUGE! Do the math and you come up with an impressive mean piston speed of 4160 ft/min at 6500 RPM. Take a look at our chart above. We are deep into the "very short life" area.
Using the formula above, we can see that the Flatlander kit hits the “Very Short Life” barrier at 6,249RPMs. Can you exceed this RPM with Flatlander’s kit, with out flying apart. Yes, however the engine life will be greatly reduced.
Hope that answers your question ;)
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Free bump. As I am also wondering,
And once it gets answered correctly, has anyone gone the other way and destroked a 7m to increase rpm's??
sorry dirgle, didn't see ya there. :)
Dirgle
Conjurer of Boost
Pauma Valley, CA
The only people I've heard of destrokinig the 7M is HKS on there MKIII drag supra. They have had great success destroking the 7M to 2.89 liters, hitting 800+hp and revving it to 9,000 RPMs. This gave them an 8.09 second 1/4 mile pass on their tube chassis MKIII, with mufflers and on wet track conditions.
Allan_MA70
1,055
Melbourne, Australia
the 5m crank (~85mm stroke) can be used (same bore-stroke ratio as the 1jz but 2.8ltr) its no weaker then the 6m crank, but still not as good as a late 7M crank.
you can also go the M-EU crank for 75mm stroke and get your hands on some M-TEU rods! but your going to need a SERIOUS valve train to make power!
figgie
Twin Cities, Minnesot-ah
sorry but I am going to disagree with Mike. At 94mm stroke Ryan woon is pushing the 3.4l engine to 9500 rpm.
BMW in their S54 redlines that engine at 8000 rpm from factory. and that is with a 91mm stroke ;)
and btw the piston speed in both those engines exceed the "recommended" limits.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
cause there are made to do that
Raven97990
230
Georgia
www.speedforsale.com
Ditto...
Rods break under deceleartion, under exhaust stroke... because it has to stop the piston from moving up..... and start it down... Both the 2j, and these other engines mentioned have lighter pistons... when you pair the piston wieght to piston speed, thens when too high of a rev coms to play.
MK III supra people tend to be cheap. Very cheap, meaning they'll go with Ross pistons. Ross pistons are great pistons, but tend to weigh almost 100grams more per piston then other pistons, which is where your problems tend to start..
You can also trust people who have minimal experince, have read a bunch of posts and made their own unsupported theories. You know, the guys who are saying "This company has done it, and so has this one, the 2j does this" Who gives a flying fuck? This is the 7M... and in the 7M it DOES NOT REV!!!! Piston speed and mass create problems. Do what HKS did, you have to DESTROKE, and then you can rev it.
Supracentral
10
The vast majority of Supra owners on this board use the car as a daily driver. Additionally, quite a lot of them rely on it as the ONLY car they have.
I didn't say it couldn't be done. I said is isn't a good idea. Go back an re-read my original post. I'm not sure what you disagree with.
Woons car is a marketing tool for WOTM. Ryan is always going to push the limits of what can be done, just as I did when crew chiefing the AAP drag car (which by the way ran two full seasons on the same motor without a rebuild).
I'm talking about sane engine design for a streetable motor with long life. Run the numbers on a Top Fuel motor and you'll find they run some insane piston speeds too.
And (if you read my original post) I've stated that manufacturers do sometimes go outside these guidelines for exotics & high end cars. The s54 that you mention is the powerplant for the BMW e46 ///M3, the flagship performance car for an auto manufacturer obsessed with high performance & engineering.
I'm certain BMW engineered that motor to withstand it.
What exactly do you disagree with?
figgie
Mike,
we are talking the stroker kit for the 7m.
So I can tell you that this stroker kit can infact be revved to 8000 rpm. Hell I am going to put my motor on the line and see what it can be the "grenade" limit.
Of course me along with adjuster are the only two running this kit. I can tell you with utmost confidence that if anything were to fail on this kit I would lean towards the crank grenading first before the rods or pistons fry.
figgie
I suggest you go looking for melloyellow for how a 7m
can in fact rev! As a matter of fact search for a post that I posted about this particular "myth" (i.e the 7m can not rev). IJ also contributed on that particular thread, But the short response is it CAN rev, you will run out of head flow first though but nothing a pnp job will not fix.
Supracentral
10
figgie said:
Mike,
Figgie..
Your entire post is non-sequiter.
I'm aware of the topic we are discussing. I'm aware that the two of you are running this kit.
We're talking about sane engine design, not what "you feel" or what can be done.
I've already stated multiple times that revving these motors is possible, just not suggested.
Let us know how it does over time, it may be a well engineered kit - only time will tell.
Supracentral
10
On a side note, do any of you guys have the crank throw numbers for that kit?
I'd like to the full blown stress analysis calcs on this setup rather than the quick & dirty numbers we've been using.
figgie
Mike
the crank throw is 97.5mm for the crank specialist/flatlander racing kit. Rods are 6.00 Inch length, pauters.
figgie
Raven97990 said:
Again, you refer to a "race" built engine, is the topic a daily driven vehicle being revved that high, or a full race engine revved that high?
hmm
you can call it what you want, the kit is no diffrent considering the pauter rods and the option for either ross or JE. The only thing not forged is the crank. That is a moddified OEM crank.
Adjuster
Well, after running the "Stroker" as delivered from Flatlander for about 350 miles, it crapped out, and I ended up re-building it again. (Combination of a soft set of pin bushings, and Flatlander's total screw up on ordering the parts, and then not owning up to their screw up's...)
So, with the crank re-worked again, and the journals hard chromed and then ground true, and Pauter using hard bronze pin inserts, the motor has now held up to some regular abuse and use with not too many problems.
If I was going to do it all over again? I'd either just do something simple like convert this car to a LS3 based V8 with twins and standalone ECU, or get lighter pistons from JE, still do the coatings, and the oil system and all the other mods since the 7M Stroker motor is really fun to drive on the street, and make's silly amounts of tourqe on a mid sized turbo. (Spell that tire smoke at will in the lower 3 gears.)
I'm in the process of going to a larger turbo and fuel injectors, and ditching the whole MAF thing for the Maft Pro to control the fuel and air calc's.
Should be good for nearly 600rwhp when I'm done, but I'm not going to claim any HP or Tq figures untill it's up and running and strapped to a dyno. :)
