Stroked NA
Nomad707
Im From The Bay
Mar 14, 2007
1,039
Santa Rosa, California
umm... that isnt the point, the point is you dont know what the motor is going to be like, and its cheap / logical to do it now.. plus you'd need to change the compression ratio because turbo's dont like high compression.. (you dont NEED to, but it would be smart to do so)
jdub
Feb 10, 2006
10,730
Valley of the Sun
High compression is good for low end, even on a turbo motor. The problem with increasing piston CR on a turbo motor is the effect it has on dynamic compression when the motor is in boost....it increases...a lot. That makes a turbo motor more prone to detonation at higher boost...not good. It's easier to use lower CR pistons to avoid that and increase top end power using boost.
8,897
Nomad707;1167086 said:
then why do all models of cars that have a turbo option, the turbo has less compression and NA has more??
its easy to raise compression so why didnt they?
It is cheaper to use low compression than a forged piston. A 12:1 engine with, just for the sake of argument, 8 lbs from a T04B, will out power the same engine with compression at 8.5:1, all through the range, without question.
You need better fuel, and more of it; i.e. a good tune.
8,897
Nomad707;1167249 said:
oooh.. ok.. so when your running a turbo on high compression without the right tune it will combust prematurely?
The combustion triangle in an automotive application is compression, air/fuel ratio, and ignition timing. But like the natural world, if you have enough heat, you will ignite without an ignition source. Provided the A/F ratio will allow it.
In the late 80's, a Honda race car, I couldn't tell you anymore if it was Formula One, or Indy League Racing, had 16:1 compression and 55 PSI.
figgie
Twin Cities, Minnesot-ah
Probably IRL.
They were running 45 PSI on top of the straight methanol.
F1 was using tolune cut with n-Heptane to reach the octane requirements.
edit: for clarification.
figgie
IJ.;1167383 said:
^ That would be really good for your complexion :aigo:
well remember, that was before they figured that is was not so nice to your skin, hair, eyes, brains, lungs etc. ;)
They probably would have used straigh benzene but they knew about the nastys in that stuff from a while back!
Alan
82
Gulfport, Mississippi, United States
I asked this question earlier. Well I see that there is alot of work and money to invest in a project like that so I have decided to look for a 2JZ and put that in my car but now here is a new question for you all do I use the factory Mark 4 ecu or do I use a stand alone?
figgie
On a stroked 7m motor. The Volumetric Efficeny of the engine changes way to much to rely on the stock ecu for anything! Stroked engine require full control of both the ignition and injection with control of WHEN injection happens (ie full sequential injection).
