Streetable yet sticky tires??
suprafanatic
1,607
Greenwood, IN
so i just went to the track tonight. its an 1/8 mile track and my car would just spin the tires half way down the track. off the line it would just spin, shift to 2nd gear the car would start fishtailing. third gear they finaly griped.. my best time was a 9.2 i know if it wouldnt spin so much i would have a much better time. so iam looking for some advice on what kind of tires to get that will hook good on the road and track, and be good streetable tires that will last for a decent amount of miles. i dont go to the track very often. i have 17in rims also. so if you know any good brands and so forth please help me out!! i know drag radials are street tires to but i'v heard they dont last very long on the street.
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
I just mounted some Nitto 555s on my MkiVs yesterday. Haven't launched on them yet but I know there VERY sticky!
Before the Nittos I had some BFG G-force sports that were pretty sticky! Lasted pretty long too! 400 treadwear tire.
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
My uncle runs some KDWs on his Cobra and he said they hook wayyy better than his Nittos did. I know he's making more power than you, too, so if they work for him you should have no trouble. He was fishtailing through first and second with the Nittos.
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Really? Thats sweet! Im running only 15psi on my T-70 right now. Need bigger injectors! Ill let you guys know how well the Nittos hook up later.
suprafanatic
1,607
Greenwood, IN
ok thats another question i had,, i have the stock saw blades also.. would i be able to run better times with those over bigger rims that i have on now? as far as the weight difference goes?
CaptMKIII
75
Kansas.
If they are lighter than yeah more than likely.
suprafanatic
1,607
Greenwood, IN
what do you guys think about the BFgoodrich G-force KDW2 NT's? price isn't bad and i'v heard good things about them.. also my rim is a 17 by 7 i do believe.. it has 225's on it right now, so would a 245 fit my rims? or would a 235 be better? i want something wider and a somewhat of a buldgy look to it
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
Keep in mind that that is a 530rwhp V8, should go better for a Supra :biglaugh:
Make some videos! I've been considering T70s as my next turbo.
shaeff
Kurt is FTMFW x2!!!!
11
Around
The benefit of the smaller diameter rims is that they allow for more sidewall flex. Stock sawblades are pretty heavy, in my opinion, so using them for weight savings probably isn't the best idea.
Sidewall flex (find the right air pressure on a tire meant for your application), sticky tires, 15" rims= Hook and GO.
shaeff
11
Around
Poodles: LOL, yeah. But you'll hook for sure!
Project: Yes, I know, but if you throw some 15" Weld wheels on there, you'll have more room for a thicker sidewall, hence why I stated 15". ;)
shaeff
11
Around
Right on. :) If I were into drag racing, I'd grab a set in a heartbeat, but they most likely won't fit over the brakes I'll have out back.:(
CarlosPTR210
435
Calexico,CA
www.ptr.com.mx
Here 18" Nitto NT01 Drag Radials
http://www.nittotire.com/#index.tire.nt01
Great Tires, but not good for wet roads.
My best time in the 1/8 was 8.8, with that tires the clutch disk fail,
now I install a 6 punk disk
but I don't have the opportunity to test it.
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
Can't go wrong with BFG's, but sounds like the problem isn't your tires, a little throttle control is what most Supra owners need. I assume you've red the supra drag racing guide sticky?
