Street/Strip Cam
Suprapowaz!(2)
2,870
San Antonio, Tx.
The reason why I'm interested in some cams is because I want to replace my stock ones. They run about $300 for a the pair. I read on supraforums.com that Shcneider Racing Cams will do regrinds for $150 a pop (with your core), whatever profile you choose. That's why I was asking how to choose cams. I've also read somewhere that you don't want to go larger than 9mm lift. Something about flipping the shims after that point. I have no clue about duration though. Maybe I should just copy you IJ and hopefully have the same luck as you.
Kurt: LOL :icon_razz
SP2: If I was doing it again I'd go larger but I rev my motor hard so the extra breathing room up top would be nice!
My specs will make you smile though as they make good power off boost and all the way to the limiter without being nasty at idle!
