strange oil pressure cranking problem
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
i've noticed that you guys can crank your cars and get an oil pressure reading on your gauges, now prior i could understand not getting it as we have digital gauges and they are all off while cranking. Now i have a prosport analogue gauge and i still don't have oil pressure showing up on the gauge.
I pulled off my oil feed to the turbo and that will not get pressure on cranking.
I also noticed that my sump was still full capacity and it shouldn't be as the oil should have gone to my filter/thermostat/cooler which should lower the level decently.
Its not just mine i've had this on, i've had it on 1g's, 1j's and 7m's be it analogue or digital gauges (90% of 1g's & 1j's came with analogue)
So why do you guys get pressure on cranking and we don't?
I"m going out to buy a syringe tomorrow so i can feed my turbo manually before i actually start it.
Oil pump is mechanically driven so is it purely just not enough engine speed at cranking to get enough pressure up? (i have heard from others that they can get pressure up by manually cranking it, so whats going on lol)
p.s... yes
you heard right. Tomorrow it will be started if all goes to plan and i'll grab a video :D
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
if you think about it, if youve got approx. 5 psi at 750 rpm i wouldnt expect much if any at ~300-400 rpm. Even if theres almost no pressure you should still have flow though.
I pack my pumps with Castrol LMM grease when I assemble them.
This creates the initial suction allowing the pump to prime.
I see 20>25 psi cranking long before the motor fires.
jmanbball
Yellow Jacket
Apr 17, 2006
234
Hittin' the books at Tech
If you wanted to prime the engine without cranking it, couldn't you spin the oil pump up with a power drill before putting on the timing belt. It would be like priming a SBC by chucking the shaft of a screwdriver in a drill and spinning the oil pump through the distributor hole.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
IJ. said:
Coolant right away
Corrosion on bare metal starts in minutes so why give it a push start in the motor ;)
I had read something somewhere about running strait water after a headgasket job to help it seal or something like that? Do you have any idea what im talking about or am i insane
