It sounds like a vacuum leak. I had a N/A supra and some dude messed up on vacuum lines on the intake side. It was idling like crap. Plus the ticking noise after you turn off the ignition is normal on N/As, thats what they do. Also, if your vacuum lines are okay, then, try to make sure your fuses on the driver side are in good order, some supras have been known to have poor assembly ( read poor contacts). Make sure everything is fitted properly.
