Stop light problem......
gaboonviper85
3,236
Northeast Philly
Tajabaho1;1414984 said:
0.o apiphany!!! ok, I'll check em asap........
so uh..........just 1 ground would make all the lights not function?? 0.o?
can I re-ground them somewhere?
the housing's plastic, how da fuck does it conduct electricity???? or is it connected to a metal rod?
No they have to touch the metal housing you put the bulbs in....I just have too keep retightening the screws....
But this isn't your problem....your problem is elsewhere....
Tajabaho1
117
Socal
for the last time, I didn't mis-wire it!!
green with green-red
red-blue with green-white!!!
how can you POSSIBLY freaking mis-wire it!!! - -
gaboonviper85
3,236
Northeast Philly
You'd be suprized at what this forum can see!
It's very late....I'm sure tomorrow some more people will chime in.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
EDIT: Ok, I see it.. switch side. Still, I think it's miswired... somewhere there's a short and a break.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
Did you put the bulbs in the right way? ive seen backwards bulbs back feed power to the parking light circuit witch would be dash and parking lights front and rear.
Tajabaho1
117
Socal
cre, seriously, .....
CRE
Oct 24, 2005
3,485
Denver, CO
Read my edit... I was thinking white/green... sorry.
Regardless, the only place for you to have a mixed problem with those two circuits is at the failure module's harness or in the taillamp housing.
Tajabaho1
117
Socal
^ and the link you gave me said the same thing!!!
quote "Cut the green w/white wire and the red w/blue wire. Splice them together. Now cut the solid green wire and splice it to the green w/red wire."
WEOITJQT^I^M#$^MQ^L
Tajabaho1
117
Socal
I'm pretty sure I did it the right way though, I'll try it again just to be sure
CRE
Oct 24, 2005
3,485
Denver, CO
Using a multimeter test for continuity across green, green/white and green/red.
I presume you have no knowledge of what your uncle's modifications involved? It's definitely possible he changed a couple things in such a way that nothing's going to work "by the book" until things are first returned to the expected state. Is the wiring he hacked in the same area?
Kota
105
michigan
same thing happened to me when i rewired mine, you must have made a mistake or you have wires shorting out
Tajabaho1
117
Socal
he didn't really do anything to the wires, he just sort of jiggled a ground wire or something........... sigh,
besides, it happened BEFORE the rewire, which is why I decided to bypass the stupid LFM(which was all shorted out anyways)
Tajabaho1
117
Socal
ok.............gaboonviper is correct!!!@
mother fucking ground bolt thingings in the housing came loose and caused the shorts etc etc.............now, they all work!!!
woot!!!
