stop fuse
sharpknife88
14
Scottsdale, AZ
hey how u doin guys?
I had a problem with my stop fuse today were it was completely melted,so i tried replacing the fuse with two different 20amp fuses,but the fuses would work for few seconds and then stop until i start slightly moving them and would do the same thing,work and then stop,so i tried a 25 amp fuse and it works perfectly,so the question is that is it risky to use a higher amp than the stock?..thank you
If you want to fry your wiring and maybe start a fire, go ahead and use a higher amp fuse.
