Stock oil cooler hose size
jaxtaterror
31
jacksonville, fl
Any one know the size of the stock oil cooler hose? Mine are leaking badly, and I want to do a quick replacement so I can drive the car once in a while.
I'm going to do a complete oil cooler install, tstat, braided hoses, etc when I install the new engine, but just want to replace the lines quickly until then.
I don't want to order Toyota lines as my local dealer never has this kind of stuff in stock and don't want to wait for the parts from Jeff Watson.
Thanks,
Don
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
thanks... i was wondering the same thing. im changing out my oil cooler in a few weeks and dont want to find out i need new ones when i go to put the new one in.
where did you order the lines? what kind did you get?
turbo87mk3
holley
jaxtaterror;826917 said:
I just bought some rubber transmission oil cooler hose 3.8" from advance auto. Cheap and easy.
does this work well? my oil cooler hose popped laast night and i had to drive the car home with around a quart of oil in her... :(
92nsx
2,957
Clearwater, MN
I have used 3/8" "fuel injection" hose for mine before I upgraded my oiling system and had no issues with leaking. Worked good. IIRC it was .50 cents a foot at the parts store. Cheap and easy fix for you bud.
Letsride
183
NC
jetjock;1538897 said:
There's no way real fuel injection hose is .50/ft. More like $4/ft. You got hosed :)
Got to agree with Jet here....the stuff I bought was about 3.50 a foot and had the blue liner inside...real FI stuff...:)
