http://www.a-t-s-usa.com/ats-products/lsd-application-DF-toyota.htm the list showing that almost every car can run the same lsd unit. I would think the MX83 has the same as the JZX81
"sourced a dead MX83 diff from another wrecker and are going to transfer the LSD internals into that"streetknight said:its posible a little searching on the web and found this http://www.itplanet.net.au/Cressida/Cressida.htm does not give much info on how he did it but try asking.
please let me know. I dont plain on getting it this weekend so it will be great knowing in advance.PIONEER said:If you can wait til this weekend, I'll let you know for sure. I'm gonna take the Supra Guts out and see if they'll fit inside the cressida. If I recall correctly, I have asked this question before and was told the Cressida N/A open diff is a 7.5" and the supra is a 8"
Look here
http://www.supramania.com/forums/showthread.php?t=341
Jeff Lange;23588 said:All Turbos have LSD.
Some N/A's have LSD, check the data tag in the engine bay (on pre-89 models) or in the door jam (89+ models), check the axle code, it will be G282 or G284 for non-LSD, or G285 for LSD.
89supraa;1585216 said:Mine is a factory turbo, but only spins the right wheel. I went to check the axle code and i was unsure which one that is. is it the part that says A/TM? If so mine is not any of those 3 options and is G305? I didnt see any other numbers besides R154,and the vin. Was wondering if i have a broken LSD or if i just dont have it. Thanks!
heavyearly87t;24240 said:If I want 4.11 LSD,or something goo for the Qtr mile, what cars am I looking for for a swap? Do I change the whole diff, or am I just changing the guts? I know that there is a mythical N/A LSD but I have yet to find one.
