stock injector limit
kozzman555
62
Ft. Benning, GA
hey whats up. ive got a 1jz twin turbo mkIII. im wondering what the stock fuel injector limit is as far as power goes (i.e. increasing boost). ive got a walbro 255 fuel pump installed already and would get a safc before messing with the boost levels. can i safely increase the turbo psi on my stock injectors? and if so, how much? thanks for any help
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Stock turbos will likely fail before you hit the limit of your injectors.
340ish whp is about the highest those injectors can take, or the highest I would trust them.
RockPaperSwoRD
I have aCustom User Title
Jul 26, 2008
392
SanAntonio
get an aeromotive fpr if you dont already have. stock 1jz goes pig rich at about 5k. i wouldnt mess with an safc unless you have a wideband either. i wouldnt go anything over 17ish psi though the twins fail at higher boost levels
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
I run 17psi +/- on stock injectors with a Neo/WBO2, though its still a bad idea IMO. Especially when you have not only 440's but also 550's sitting around like I do.
kozzman555
62
Ft. Benning, GA
it seems i have diff people saying diff things. basically what i want to know is what do i need to do (other than buying a boost controller and fcd) to safely boost 17psi on my stock twins?
seoul4korea
620
San Diego, CA
www.supraforums.com
They answered your question you just didn't read it all. Sure your Fuel pump is important but if your running stock injectors then that only leaves the Aeromotive FPR and/or a piggy back or standalone.
