If you were actually asking for an explanation, then fine. You just seemed to come off cocky in your first comment, as if to suggest that I didn't know what I was talking about. That's why I responded in the manner that I did. Oh well, I'm often mistaken for being rude as well, so no big deal.
I don't remember off the top of my head how to adjust the idle on the '89+. If you look around the back side of the TB while the car is running and experiment with the assembly that the throttle cable is hooked to you'll probably figure out what to do to adjust the idle. I believe that there is a tiny bolt with a locknut on it that did the trick for me. Just be careful not to adjust the wrong piece of hardware too much or forget what position it was originally set at. If you have a paint marker or something similar (what all that hardware was marked with from the factory) you can mark the original position of each bolt.
The picture that Staticpat has is from the pre-'89 throttle body. The '89+ doesn't have that screw on it.
