stock fuel regulator vacuum?
mk3 bamf
The Red Dragon
Jan 31, 2007
229
washington
Can I just run the vacuum line from the fuel regulator to manifold vacuum?
Or does it need to go through the sensor thing.
Thank's in advance
desmd99
57
selangor
can anyone show me where is the sensor? I have gone to single turbo and did a little piping on the intake and intercooler piping. My gas mileage quite bad.
dbsupra90
toonar
indiucky
GrimJack;908032 said:
It should go through the 'sensor'.
The VSV switches the fuel regulator vacuum source to ambient pressure when the engine is cold. So it helps the engine run richer when you start.
i was pretty sure it was the other way around. the vsv closes during warm starts to increase fuel pressure to combat heat soak.
desmd-
it is a small round brown sensor under the intake manifold. it has a vac line on each side of it, and a 2 wire plug going into it.
