How much can a stock crank hold power wise I need to order 1 before 4pm, or I can't get it till Monday?????
jdub said:Keep in mind the stock crank will have to be balanced and all the journals turned (if req) to hold that kind of power. The journals will have also to be in TSRM spec.
Adjuster said:The 7M engine is a good design crank and mains wise.
You have 7 mains.
And the crank is forged from the factory. (V/S cast which is cheaper, but not as strong.)
Fixed it for you. This is assuming a major build up.Supracentral said:Properly prepped & balanced, the stock crank will hold more power than you will ever make.
Focus your energies on:
Head Gasket
Rods
Pistons
Valve Springs
In that order.
Nick M said:Fixed it for you. This is assuming a major build up.
