If crankshaft pulley degree angle is within 5° of TDC, crankshaft pulley degree angle is correct. If crankshaft pulley degree angle exceeds 5° of
TDC, note the following:
a. Using tool number 09278-54011 or equivalent to prevent camshaft sprockets from turning, remove camshaft sprocket bolt.
b. Ensure No. 2 camshaft journal housing and No. 2 camshaft journal holes align, Fig. 110.
c. Using a suitable magnet, remove alignment pin from camshaft sprocket pin hole.
d. Set No. 1 piston to TDC of compression stroke, then insert alignment pin through camshaft sprocket and into camshaft. There are alignment pin holes on the sprockets and camshafts. Select one overlapped alignment hole and insert pin into it, Fig. 111. If there are no
overlapping alignment holes, select a hole which is nearly overlapped. Turn crankshaft slightly to overlap the alignment holes, and insert pin.
Turning the crankshaft to overlap the next available alignment holes will change crankshaft sprocket angle approximately 3°.
Rollus;2057075 said:I've really meant to mean "you meant Yamaha right?"I'm not sorry, that's not my bad.
BTW, Please check Toyota M Lasre Alpha-X project:
View attachment 76896View attachment 76897
Finally, from the 5M repair manual:
Conclusion, that's +/-3° adjustement overlapping camshaft and camgear holes.
That's documented:
- Toyota has thought about VVTi and ASICs back in 80's.
- Toyota has intention of adjustability of fixed cam timing, each pair of holes give +/-3°, some 5M (on Cressida) have 5 holes, other 5M/6M and 7M Supra have 3.
- Honda drew up those plans and it works quite well also!
Edit: for some reasons, I haven't read Bmettie post. He is right! I like his avatar (see above) haha.
Bmettie;2057037 said:So back on topic...The holes in the cam vs the cam gear are not identical. If you have the pin in the middle hole another one will not go into the side holes, you'll have to remove the center pin and roll the gear forward or back to get one of the side holes, hence the slight adjustability.
Rollus;2056840 said:Gats, you measure 74° apart on the gear, how much do you measure on the camshaft?
FredMk3;2057058 said:Didn't know you were talking about Honda variable valve timing and lift here. Yes that was confusing
gats;2057238 said:Sorry, no spare cams to measure...
Nick M;2057324 said:
