89supraa - the bottom line on this subject is twofold:
1) To get rid of anything on the motor you really, really need to know what it's purpose is and that is not always obvious (the EGR is a perfect example). "Clean up the engine bay" crusades is a sure fire way to make the car run like crap.
2) The 7M depends on the AFM for air flow into the motor...it's failure (or it missing) will cause the ECU to enter fail safe mode. You have to go to an alternate way of measuring air flow...the best is to switch over to speed density. As mentioned, a MAFT Pro or HKS VPC (both piggybacks)...or, a standalone EMS (AEM, Motec, Stinger, etc) is the only way. I'd stay away from the MAF blow through method.
I'm closing this thread...why don't you step back and re-access. Function beats form every time
