Stilll Running rich!
bigal0043
813
Plattsburgh,NY
www.mk3supra.net
would a bad isc cause bad gas millege as well???i also pulled the efi fuse and checked for codes again and nothing.. the light does work it was flashing steady when i checked for codes
Also i have no way of checking timing
jdub
Feb 10, 2006
10,730
Valley of the Sun
bigal0043 said:
well my idle is weird... sometimes it will idle normal around 800 or so... but sometimes it will idle around 500 or around 450 which seems low to me...
Any thoughts?
650 is normal idle...900 with the AC on.
robeats91t
237lbs. of Ballast
Jun 4, 2005
210
Tampa, FL
Looking through this and back through your original thread, have you checked the clamps on your IC pipes since you installed them? I noticed mine were a little loose for comfort after a few weeks--you may have one (or many) just loose enough to cause leaks under pressure.
Also, pull off that bosch bpv and see if it holds pressure; a leaky bypass valve will exhibit symptoms of a boost leak, causing metered air to escape.
It sounds like it could be a boost leak that's causing your problems. I boost a fair amount (my car's only boosting 8psi though) and I typically get 22-23 mpg. 17 mpg is a good number; many users on the boards here report much worse mileage with their modified cars--however, 100 miles to a tank is like 6 mpg...
I'd recheck every IC hose clamp on the car, and also check that bosch bpv. Also, check the IC itself for leaks caused by physical damage (rocks, road debris, etc).
Good luck!
EDIT:
bigal0043 said:
I also have a slight leak on my turbo elbow that wouldnt cause it would it?
I had a slight "aha!" moment, and was going to say something about this, but logically it shouldn't be a problem. Exhaust gas escaping near the O2 sensor may cause a problem, but not what you're experiencing. The biggest issue would be if outside air was somehow introduced--this may cause the O2 sensor to read a false lean condition and introduce more fuel. Since you mention this happens most under boost, it would seem this couldn't be possible, as exhaust flow exiting the turbo and backpressure from the exhaust system would pressurize the exhaust enough to disallow any air introduction through this bad seal. Please please PLEASE correct me anyone if I'm wrong--but that's how I see it.
bigal0043
813
Plattsburgh,NY
www.mk3supra.net
how do you check a bpv again??? i will check my clamps and look at the ic for leaks as well... oh and the 100 miles to the tank thing was how long i did my testing the first time to see how many mpg i was getting.. My gas gauge acts up sometimes so i usually fill up around 100- 150 miles.. Usually around 6-7 gallons to fill it give or take a gallon
robeats91t
237lbs. of Ballast
Jun 4, 2005
210
Tampa, FL
A simple way to check the valve is to pull it off and see if you can blow through from either side. Also, if you can get your hands on a vacuum pump, pull a few inches of mercury at the vacuum port on the bpv and see if it holds it for a minute. Ideally you'd want some way to check the valve itself with 10-13 psi, but that would require fabbing up a pressure tester.
Personally I had problems when I ran bosch bpvs, but I may have been a weird case. The diaphragms kept ripping on me; went through 2 in a one-year period of time. As far as I knew from my AutoMeter boost gauge, I never ran more than 11 psi.
GotBoost?
I do
Nov 25, 2005
318
By My Computer
How does the car idle/run when cold? Have you checked your temp. sensor (in the thermostat housing)? I'm thinking cold start injector. I don't know if the ecu throws codes for this.
bigal0043
813
Plattsburgh,NY
www.mk3supra.net
in the tsrm it stated to check the plugs i mentioned... ill go back and check the ks with what other plug?
btw i have no cat ;)
also got a new multimeter.. its nothing spectacular but its better than nothing
robeats91t
237lbs. of Ballast
Jun 4, 2005
210
Tampa, FL
jetjock, great info there. I should have merely put forth the question and let someone who knew what's what follow through with some solid facts. Next time I'll make better use of research and scientific fact instead of flailing about with "common" logic.
The first thing I thought of when I re-read "slight leak on my turbo elbow" was how older cars with exhaust leaks sometimes tend to backfire from ignition of the unburned fuel, which I thought was caused by the heated, unburned fuel in the hot exhaust manifold/exhaust system mixing with enough atmospheric air through diffusion (thanks jetjock) to create conditions favorable for autoignition.
So, in conclusion, to take a line from jetjock:
jetjock said:
Exhaust leaks also cause grief...by increasing the amount of O2 present in the exhaust stream. Any leak along the exhaust will cause this problem but when it comes to closed loop operation the exhaust needs to be leak tight near the O2 sensor and especially upstream of it.
