Nick M;1827956 said:No PCV of any sort?
IDL=Idle. The TPS has contacts that open when you accelerate. They close when you take your foot of the pedal. That is deceleration fuel cut. But I am thinking that isn't your issue. You can check for a 51 anyway.
The PCV doesn't cause a car to smoke when operating correctly. However, if you have nothing, you will have higher than normal crank pressure, pushing oil from where ever it wants to give. I think that is the core issue.
kakanator;1828415 said:it only smokes if im deccling for a long period of time like 5 to 10 seconds no other times but it also doesn't do it ever single time i deccl.
kakanator;1828819 said:OK so i did a oil change and at the same time did the valve cover gaskets and checked the fender to TB piping and it was all dry. Also checked the one for part that goes into the intercooler and it was all dry so no oil that I can see from the compressor side.
