step by step on how to remove full pumpkin,anyone?
89boosted
88boosted
Jan 3, 2008
58
Morrison
could anyone tell me the step by step directions on removing complete differential? what type of stands to put it on ect ect. order of removing drive shaft and axles, any gaskets? also when u remove the propeller shaft it says to make match marks, would i have to do this if i was replacing the full pumpkin?
A-to-the-J
Panda™ and Pre-89 Gracer™
Feb 19, 2006
1,080
Anaheim/West Covina, CA
i don't think it really matters, just make sure after you install your new pumpkin to line up the holes correctly. It took me a few hours my first time replacing it. I was by myself.
make sure you have some PB Blaster
it makes things quicker. Also a pry bar would help after you unbolt the axles. my steps to taking off the pumpkin were:
unbolt driveshaft, unbolt axles, setup jack underneath pumpkin, unbolt pumpkin. but you'll have to wrestle out the old pumpkin and wrestle in the new one. it's kind of a pain. if you're doing it by yourself, you're going to have to unbolt the axle one or two nuts at a time because you'll have to pull the e-brake so the rear tires don't spin.
89boosted
88boosted
Jan 3, 2008
58
Morrison
alright thanks for the help, also when u put the new pumpkin in, do u hav to torque anything to certain specs?
89boosted
88boosted
Jan 3, 2008
58
Morrison
and one more question, when filling the differential fluid how much do u put in?
bmoss85
Permanently Banned Scammer
Apr 14, 2007
1,026
clemmons, nc
after you unbolt the axles and driveshaft, i think are only six bolts that hold the diff in place.
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
Raising and lowering the diff with a floor jack is very tricky. I had to build a flat stand out of 2x4's that then bolted to the top of the jack where the cup sits. It then allows you roll the diff around and adjust the height as you get read to bolt it in. I don't think I could have done it without it.
