in the process of finishing my 1jz swap/build, I had to bleed the power steering - did that. however now, when on the ground, engine running, the P/S pump makes a high pitched sound only when you turn the wheel, and theres another sharp noise coming from the rack area it self. I bled the system again, double checked all my connections, still persisted so I had a friend comeover and turn the wheel while the car was down on the ground, and me looking in the engine bay to try and find this noise (which is where id iscovered it was coming from both the pump and the rack)
But then I noticed something else as well - the whole steering rack assembly would move side to side as you turned the wheels. Not only that, but the motor did a little bit as well, leading me to believe that the whole front subframe was shifting when load was applied to the rack.
My car has H&R springs, so its stupid low, but the amount of camber I have is abnormal - someone on here a while back suggested taht my front subframe bushings might be worn, and thats putting my suspension out of geometry. Could worn bushings cause the lateral movement in the subframe as well? If so, who sells these bushings? I've been searching all over and can't find em!
I also put the car back up in the air, and did an inspection to see if there were any major visible cracks... no.
Also obviously lose subframe -> unibody bolts?.... no
Balljoints.... no movement
Any ideas? Tips? I gotta get this thing driving so it can get painted so I can make the centralia meet!
