I took the rack off as the pass side boot was leaking.
The driver side boot was full of oil too.
It doesn't look like there is a seal for the driver side. Should the driver side boot be full of oil?
Should there be oil in the pass side? Is the pass side the only side with a seal on the rack?
If the pass side is not to have oil in it, when you rebuild the rack, are you just replacing the seal on the pass side? What else is done on a rebuild?
Edit,
I searched and I think there should be no oil in the rack, right?
I assume its the pump that is leaking into the rack, is this correct?
Edit,
