Preface:
-The following is a good guide on how to remove the oil pan with the engine in the car. Many of us do not have the equipment to "pull the engine" for every problem. With this you can re-seal the oil pan, change the oil pump or attempt some bottom end work.
-I successfully cured rodknock using this, but it is not guaranteed by any means. This is like the $50 paint job how-to's, it will work but isn't the best method by far. I was successful because I parked the car as soon as I heard knock. I took my time, kept everything super clean, checked and re-checked my clearances. I'm no engine builder, but I tried my best and it worked.
-Depending on your situation this may be a good cure. I already had a spare project block when I developed rodknock. For me it was either spend thousands building up a powerhouse block or try and spend a few afternoons and $50 to see if I could get the car running good. If it failed, I was only out $50.
*Note I had a sheet with all the bolt sizes, if I find it I will update.
On with the show:
Part 1: How to Drop the Subframe:
Heres the TSRM page http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=LU&Page=7
-Jack up the car, secure it on jackstands.
-Remove front wheels
-Drain the oil
-Disconnect oil cooler line from block
-Remove block to transmission braces.
It's a good habit to rethread all your bolts. If I have to tell you this, then you probably shouldn't mess with your bottom end.
-Remove rubber thingy between body and motor.
With that out of the way let's move on to the suspension.
-Disconnect the tie rod ends.
You will need an alignment after you disconnect the tie rods. I spraypainted the shaft so I could get the alignment close enough to drive when I reinstall.
A)First you need to disconnect the bolt that holds the clamp which fuses the 2 pieces.
B)Unthread the shaft by putting a hand wrench on the flat sides of the rod. One side was seized and I needed to heat it up with a torch to break it free. 200 turns later it should be out,
-Disconnect the stabilizer bar end links. You have to hold the back of the stud from turning with vicegrips or something.
-Disconnect the lower shock bolt. When you lower the subframe remember to move this out of the way.
-Remove brake line brackets from brake caliper. Break clips off other break hoses. I disconnected the brake lines from the body because I was planning on taking the subframe completely off. You probably don't need to disconnect them.
Gross!
All disconnected
*You will need to support the engine from here on out, it will no longer be sitting on the motor mounts. You can use a cherry picker or whatever. For God's sake make sure this is secure, the last thing you need is an engine falling on you. Keep in mind you will be torquing hard later on.I made my own redneck brace between the shocktowers. If there is enough interest I will start a groupby.
-Disconnect the motor mounts and do what you need to do. I jacked up the engine and hooked up my contraption.
-There are 2 nuts and 1 bolt on each side for subframe.
Support the subframe in the middle before disconnecting. When it is supported you can break it loose, and let her come down. I held jackstands on both A-arms to keep it in place, so I could play underneath.
EDIT: It appears this picture is holding the engine up. Obviously put the jack under the center of the subframe.
I may need to go to the jackstore.... I'm running out quick.
Here is a shot of the clearance you get to get the pan out. Don't let too much weight sit on the steering column etc. Like I said, support the A-arms on either side of the subframe.
I'm tired now, I will post how to take off the pan/fix rodknock tomorrow.
On with the show:
-Drain the oil
Gross!
All disconnected
