starts but wont start again
ssb360
12
Corvallis, Oregon, United States
so i had a bhg in my 91 and fixed it but then it stared a few times a high rpm and then died. i dont think that i have the right size of battery, the bet that we put in there was out of another car and had 570 cca. what is the right cca for the car and would that fix it?
AJ'S 88NA
2,419
Florida
Don't think the battery would cause it to have a high rpm. How's the timing set? And have you set your TPS?
AJ'S 88NA
2,419
Florida
ssb360;951739 said:
never messed with the tps and the timming seems to be fine
Have you set it with a timing light? Are you sure about all the marks lining up, cam gears, crank @"0", #1 at TDC, and rotor pointing at #1? After all that you set the timing with a light.
