Starts beautifully. Throttle stutters/stalls
S.A. supra
2,405
Buda, Texas
Ohm and feeler gauge.
I put mine on wrong and it did the same thing. Hit 3500 and just cut out hard. I couldn't even get it out of second gear.
Also once I had a stall problem and low idle. It ended up being the gasket on my throttle body.
Have you checked what your plugs look like?
Supra_dan
313
north carolina
Ok so, before I go and try to tackle this tps thing.. Can that be what's causing break up at part or even full throttle?
Also the thing that bugs me is that, can the tps cause the car to pour out black smoke, I.e. run very rich and bog itself out?
Supra_dan
313
north carolina
Okay. Jeeze, so I literally took off and retightened every hose I can think of on the car and well, it worked.
I apparently had a leak somewhere.
Thank you everyone for your fast and helpful responses!!
