Starting & Idling Issues after HG replacment
TuRbOdReAmZ87
Supramania Regular
Feb 2, 2007
813
Southern mass
Here are a few videos of my supra after i replaced the HG. No, the HG is not blown. lol It runs decent in the second video. Still need to change the oil twice more, and oil filters. As well as replace the timing belt. Vac lines. I guess i need another VSV. And CSI. It is throwing codes but haven't checked them yet. Any comments or opinions let me know.
Here's the first one. Oil still milky. Left over coolant burning off
http://www.youtube.com/watch?v=E5wH6P-QDEU&feature=channel_page
Here it is after warmed up. She died a few times but then started right back up. No more smoke. :icon_surp
http://www.youtube.com/watch?v=RhplYzsD-OU&feature=channel
kinda sounds like your timing might be off a little. and its not really warmed up yet.
zambini
464
Detroit, MI
either that or your plugs are fouled or wires are in incorrect places ( TSRM IS WRONG!) or wires are bad, or coils are bad or a bad ground in the spark system. (less likely)
TuRbOdReAmZ87
Supramania Regular
Feb 2, 2007
813
Southern mass
Well im gunna check everything this saturday. There are some vac lines that are missing. And I guess a vsv that goes underneath the intake manifold.
As a matter of fact ill take some pictures of where the vac lines are absent and maybe get some ideas.
kotu100
1,899
Easton, Ma
wow i dunno how i missed this, grats on gettin her running!
that may very well be the timing causing the noise, but you really need to check the codes. its a minute and a paperclip, and it helps a lot.
DigityD'87
236
Portsmouth, NH
My car did the same sputter due to an extremely dirty throttle body plate. A little wire brushing did the trick for me. When that plate doesn't remain shut for any reason the motor will try and die out.
P.S. Did you have that on craigs list a while back? I think I tried buying that off you, lol.
TuRbOdReAmZ87
Supramania Regular
Feb 2, 2007
813
Southern mass
Yea i think it was on there before the HG blew. lol
thedave925
Since 9/16/05
Nov 9, 2005
626
East Bay, Cali
Fouled spark plugs maybe?
CPS is off a tooth?
Is your intake mani and throttle bodies well sealed?
Did you modify your EGR in any way?
timing sounds retarded.
Supra90gr
116
Connecticut
TuRbOdReAmZ87;1342830 said:
True that. I'll have to check the cps. Didn't think of that, I figured it was fine. Maybe I'll take another video of it running tomorrow. Only thing is I need a new timing belt.
Sounds like timing.... Mine did the same thing after a headgasket job....I freaked out and but then timed it and the engine purrs like a kitten now.
