starter problem...... any suggestions ladies??
Status
Not open for further replies.
Aznfryboi
10
Sacramento CA
I have a 1990 turbo supra, it cranks, and yes it alline straight!! (cams and crank) and when it cranks, its about to start, then it stalls, but there seems to be some spark that will pop up, near the intake manifold when trying to start it. I need help from the right mens, and fast too.. have any suggestion?
Aznfryboi
10
Sacramento CA
Whasian said:
You should take the starter in to Autozone or Kragen. They test for free and can tell you what is wrong (if anything) with the starter.
Whasian
the starter works great, already done that it past all the 3 stage. it's the engine i'm having problem with trying to start it.
suprahooked
Built 7M
Jun 20, 2006
1,160
pa
Aznfryboi said:
i dunno, but when i try to start the engine, it will have a spark and then starts to smell like gas near the manifold.
Check ecu ground ,starter connection make sure all are tight. Gas smell, fuel leak, loose upper and lower intake manifold bolts or loose egr valve.
Frank Rizzo
478
Fixing your girl's car
You may have the CPS 180 degrees off. This commonly happens when setting TDC with the crank notch at the 0 degree mark on the timing cover. There are 2 TDC's and you only hit the one you want once every 2 times you line that notch up with the 0 degree mark.
Aznfryboi
10
Sacramento CA
i found out what happend, the spark from the intake manifold, its comming from the pressure gasloline, i need to titen that up, and hopefully it will crank. also i will check the cps.
Status
