V
vecog
Guest
HI guys i've been having a problem with my starter or starting system. 1st off my car will startup normally but after running for a while, then turn car off, then try to start again later maybe 1hr all i get is click click. you can here the solenoid clicking but stater will not turn over. i dont think it is the neutral safety switch b/c i tried starting it in every gear during incident and you can here solenoid engaging in nuetral and park but not in other gears. so I started with a new battery then a new starter, but i get the same thing. new starter consisted of remanufactered from advanced auto. i took car to toyota $ervice dept this morning and they found that one of the bolts were missing during diag, that cost me $35. took it back to meineke and they swapped out the starter and installed a new bolt i stood under car during installation to make sure. i thought i was all set to go, went to tire shop i was had to move car a couple of times (starting, restarting no issues) then after tire repair car would not start!!!!. they gave me a jump and it started as usual. that is the thing. when it clicks like that a jump will start it right up. i did explain this to toyo and meineke. they checked alternator and battery both are good. i am going to start swapping groung wires tommorow. if any one can shed some light pleese do. thanks.
