Starter Issues FAQ
TurboWarrior
Canada
If you have a (click) when you attempt to start the car emanating from the starter motor/solenoid that is what this writeup is about. If the motor does not even make a sound when you turn the key you may have other issues.
This is a list of what is wrong most of the time
1. The contacts in the back of the starter are worn out. Take off the back plate of the actuator unit by removing 3 bolts. Remove the plunger. If you see heavy wear on the 2 contacts that the plunger comes into contact with they need replacement.
Jeff Lange
The Toyota kits come with more than just the contacts; they include the bolts, washers, etc.
1986.5-90 Starter Contact Kits:
28226-72080 Battery Side Terminal Kit
28226-72010 Motor Side Terminal Kit
1991-92 Starter Contact Kits (Same as the JZA70 1JZ-GTE 1.4KW Kits):
28226-76070 Battery Side Terminal Kit
28226-74070 Motor Side Terminal Kit.
If you notice that the contacts aren't overly worn and the contact part of the plunger is ok then there is another problem.
2. You have a bad battery or your alternator is bad and the battery is not getting a full charge. Get the battery tested or try swapping out for another. If the car still doesn't start you have another problem. Clean your battery terminals always if they look rough with a heavy wire pipe cleaner or a longer bristled wire brush. If necessary replace the terminals or wires if they are bad.
By bad I mean cuts in the shielding, weakness in the wires. A weak battery + weak wiring + old starter, it all compounds the problem. Weak wiring sometimes you can’t do anything about but if your battery, alternator, terminals, obvious grounds are all good and you know they are it narrows the problem. Maybe you replace your starter and the problem goes away, but comes back on you after a length of time. That’s other weaknesses starting to show and replacing the starter only band-aided the problem until the starter came under some wear.
Assuming the battery and charge is ok
3. You have bad or worn wiring, usually a single bad wire. Try jumping the car with another vehicle or a booster pack. If the car starts when it is being boosted (which is usually at 14v) this is probably it. The extra voltage and current available compensates for the bad wire. The single wire spade terminal (the small one) at the back of the starter should be the culprit. Try holding a wire to that terminal and touching the end of the wire on the + side of the battery. If it starts to crank that is your problem!
Either run a switch from the + lead to the cabin and from the switch back to the starter. Or replace the wire. Run your own wire from the back of the starter into the cabin and splice/connect it to the ignition switch. The exact color on the wire on both ends I am not sure of yet. I think it’s slightly different too with an automatic transmission. Either way if you do the test and connect a wire from the spade terminal on the back of the starter and it cranks, this is your problem area.
Remember that when you use this test method or mount a switch it is bypassing the safety features of the car for starting. If it is in gear the car will fly forward. Make sure the vehicle is in neutral or park.
Less common causes are the ignition switch itself, Starter relay, Neutral start safety switch itself (auto), or clutch start safety switch (Manual Trans.)
The order you should test in should be easiest to most difficult.
1. battery and charging system
2. Cleaning the battery terminals and checking the obvious grounds and leads for wear.
3. Jumping the starter solenoid
4. Checking the contacts
1 and 2 are simple. 3 can be simple with thin arms like me, if not you may have to remove some parts. 4 the starter needs to be removed. Based on your gut instinct you may change the order. Hey its a good way to learn.
If your starter clicks only when your battery is a bit low this could also be your contacts or any of the above I mentioned. The mkiii is getting old. Everything is wearing out. Hope this helps!
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
i think i recall seeing a TSB for the mkiv regarding the starter click issue and it said to add an extra relay.
basically it uses the stock starter solenoid wire to trigger another relay. then the new relay pulls power from the battery or the alternator post to give a full voltage signal to the starter solenoid. its not a large amount of current, its just to trigger the starter.
the stock starter solenoid wire is very small and can experience a voltage drop. if you have insufficient voltage coming thru the vehicle harness and to the starter solenoid, the plunger will Move but not fully extend. if it does NOT fully extend, youll hear the gear contact the flywheel (thats the click) but the contacts will NOT engage. since the plunger does not full extend due to low voltage, the contacts dont engage and the starter motor never turns.
the solution is to get PROPER voltage to this starter solenoid/bendix so it fully extends. this way, itll engage the contacts on the plunger and the starter motor will turn. the way to do this, is add a standard bosch 30amp relay.
