Nick M;1325335 said:When a stand alone uses a Hitachi mass air flow sensor with sequential injection for 6 cylinders, I will look at it.
MoTeC
Neodeuccio;1325453 said:IJ, you do realize that 99% of Mk3 owners are broke, right? :icon_mrgr
figgie;1325531 said:Hold up. There is a HUGE difference between broke and CHEAP. The correct word is CHEAP.
turbogate;1325707 said:Go with the AEM and call it a day. The fastest 7Ms may not run AEMs eventhough, last time I check, Kwnate AEM still has more power than Duane MOTEC :biglaugh: (haven't checked in a while, things may have changed) lol. I will tell you this however, the biggest HPs 2JZs in the miami area run AEMs, I'm talking 1100, 1200 hp + no matter what people are saying. Not trying to start a standalone war my supra fellas, just telling it how it is.
IJ.;1325807 said:Nick asked a specific question I answered
As for AEM being on high HP cars... so what :nono:
ASK any of them if $ were not an issue which management they'd rather run I'd be very surprised if any of them honesty said AEM.
I can make stupid HP with a set of points and a carb so following the logic here are management is crap..
Doward;1326029 said:Aaron's got a PnP harness for the Stinger, as I recall.
3tc power;1325552 said:why don't you just go with Haltech! i see tons of replies but none sound like they are from people that have actually use any of those ECU's. the haltech E6X is the perfect computer for anyone that is aka broke but got a little something to spend. for the price you can't beat it, and on top of that it has tons of features...shit it even has an out put for your A/C lol.
E6X Fuel & Ignition Computer
The Haltech E6X is a powerful "real-time" programmable fuel injection and ignition system computer designed to control most ignition type engines. Whether 1-6, 8, 10 or 12 cylinders, 1-2 rotors, naturally aspirated, turbocharged or supercharged, the HALTECH E6X can control it.
The E6X System optimises engine performance through the following capabilities:
- Ignition timing control
- Fuel control
- Idle speed control
- Closed loop
The E6X is much more than a programmable fuel injection computer - it provides logging of engine data and allows access in real time to maximise performance and trouble-shoot problems in a vehicle while running.
Typical Applications:
- Control of fuel injection on modified engines
- Conversion from carburetion to fuel injection
- Race and rally applications of all description
- Design and development purposes
- Educational use by universities and technical colleges
- Original equipment in cars and motorcycles.
The patented Haltech system of programming virtually eliminates the input of numbers. You simply manipulate bar graphs by pressing arrows keys on the attached PC running Haltech Programming software. Manipulating the bars allows you to increase or decrease the amount of fuel delivered or ignition advance at that particular RPM and load point. The process is repeated for all load points in each rpm range.
Ignition timing is precisely mapped through the RPM range so that the exact timing required to obtain optimum performance is applied in every RPM and load range.
The E6X Short Kit includes:
ECU Programmable Computer, Programming Cable, Short Wire Harness OR Patch Loom, Programming CD, Instruction Manual on CD and Haltech Stickers.
E6X Features
Up to 4 fuel and 4 ignition channels (internal toggle)
4 dedicated PWM outputs
1 auxiliary input
1 auxiliary output (tacho output)
Dedicated closed loop idle control
Dedicated closed loop O2 correction
8 injector drivers as standard equipment
An internal barometric pressure sensor
New RA8 reluctor adaptor
Rev limiter
Deceleration fuel cut
Datalogging to laptop
Flatshift
Dual Mapping
High boost software (up to 65psi with optional MAP sensor)
E6X PWM Outputs
Electronic boost control
engine control relay
intercooler fan
aux. fuel pump
torque converter
thermofan
NOS enable
turbo timer
staging signal
anti-lag
BAC valve
stall saver
dual intake valve
VTEC
shiftlighting
air con
oh and for the record! i also have this ECU and i will be using it in my 3tc Turbo ae86 which is very highly moded and it's a street car and yes a/c will be fully functional too lol.
OH yeah if you need the hook up on a good price or someone to speak with on the ecu just PM me and i'll be happy to help you out bro.
