stand alone ecu
figgie
Twin Cities, Minnesot-ah
help installing it?
it should be cut and dry.
it should have a harness.
you just need to use the stock sensors, assign them to the pins and done. Not that hard really.
Then you use the MoTeC software to configure and done.
If you don't know the how, put the soldering iron and electrical tape down and take it to someone that has done the wiring before.
ca91mkIII
126
Franklin
Megasquirt 3 seems to be the best option for my application. I have done a decent amount of research on both the Megasquirt system and the AEM V2 and the MS3 does the same thing the AEM standalone does for about $600 less. For what it is worth, I am running a forged bottom end 7M, BC stage 2 cams, supporting fuel mods, and once I get the funds together, Driftmotion's turbo kit. I want to be able to push around 600 hp with this motor and everything I have read, says that MS3 will handle it fine plus it is almost plug and play.
