car is a 88 7mgte, 244,000km, mostly stock with filter,3inch straight turbo back exhaust, walbro 255lph pump. its been sitting for a year. trying to get it back on the road. heres the situation, if i hit boost and bring it up to about 4k+ rpm and let go of the gas completely with the clutch in or if i put it in neutral it stalls. I checked for boost leaks, it boosts fine so I dont think it's a boost leak as it boosts normal(comparing it to when it DID have a boost leak). it idl'es fine, right around 650rpm, if i rev it up in neutral it does not stall. greddy bov is recirculated. timing is correct, plugs and wires are new, checked for the code 51 when pushing the gas with the diagnostic wires jumpered. what else should I be looking for?
