sr20 swapped sentra SE-R, vs shaeff's rustbucket
shaeff
Kurt is FTMFW x2!!!!
11
Around
ok, first off, here are his mods that i know about:
JDM silvia SR20 DET swap, solid motor mounts, full 2 3/4" exhaust from the turbo back, FMIC (side to side, and DAMN nice) custom mandrel bent intercooler hardpipes, greddy type S BOV, walbro 255, mandrel bent intake hardpipe, with cone filter. stage 3 clutch, and he MIGHT have a lightweight flywheel, but i'm not sure. his interior from the front seats back is gutted. (this thing is mad light, and smoked an '04 corvette up until the sentra hit speed cut) battery relocated in the trunk. he's lowered, too. he's running 6-7 psi.
here's my mods:
86.5 turboswapped chassis, SOGI short shift rethreaded for stock knob, '89 7MGTE, Clutchmasters Stage III, Fidanza Lighweight Flywheel, Lexus AFM, RC 550cc Injectors, Boost Reference Aeromotive Adjustable Fuel Pressure Regulator with Fuel Pressure gauge and stainless steel braided lines, pulsation damper removal kit and j-tube bypass, Walbro 255 Fuel Pump, Megan Racing Boost Gauge, Becauseican Divorced Wastegate Downpipe, 3" RS*R Concept Cat-back with resonator removed, Cometic 1.4mm MHG, ARP Headstuds, 1mm Oversized Valves, Dr. Jonez Manual Boost Controller, Eibach Pro Kit, Koni Yellows, Upper Hardpipe/BOV, B&M 11x8 oil cooler, B&M 180* thermostat, oilfilter relocation kit, Greddy oil catch can.
i'm still on the stock intake system (i swiss cheesed my airbox), stock intercooler and stock lower IC piping. i dont have my boost controller hooked up because i was having problems with the car, and removed it to help eliminate all other variables. (it wasnt the MBC by the way) my boost will hit 8psi, then slowly spike to around 15 in the upper gears. i also have traction issues, due to the fact that i need an allignment. i also still have the stock catalytic converter from my N/A (hollowed out, but still bottlenecks like crazy after the BIC ddp)
on to the race:
so, i meet up with him, and we go to an open, 3 mile stretch of road, and make a pass to check for anyone. there was nobody on the road. (woo!) i honestly thought he was going to pull me. his car sounds amazing. the exhaust note is beautiful. you can really hear the turbing chopping up the exhaust note. like a "blub blub blub blub blub blub" type deal. very menacing. he wanted to race from a roll, as did i.
we slow down, with me behind him. doing about 20mph, and 4 carlengths behind him, both of us in second gear. we decided the "go" signal would be to flip on the hazzards, and then turn them off.
i see his hazzards flip, and i plant my right foot into the floorboard of the car. he jumps instantly (small turbo spools faster than ours) he gets a half a car length ahead. i only hit 6psi in second. i could hear his car screaming to its 7500rpm redline, and a puff of black smoke blew past me as he shifted.
i nail third gear like i would punch a mugger in the face. it was a nearly perfect shift. i didnt even hear my BOV sound. i accelerated toward him like bullet. i let off the accelerator so i didnt smash into his rear bumper, then floored it again. my engine RPM shot to redline within an instant. i hit fourth with another superfast shift. and had to let off FOUR MORE times.
needless to say, i was capable of passing him, but the deal was that we wouldnt break 100mph. neither of us really street race, but this race was the talk of all the car kids in my town, so it needed to be done.
SECOND RACE:
this time, he followed me. he stayed 1/2 car length behind me, so that he could hear me floor it over his car. both starting in second gear, i flipped my hazzards on. as soon as i flipped them off, i heard his car begin to catapult toward my rear bumper. (too close for comfort, as he was already wicked close to me!) my right hand was quivering in anticipation of the 2nd- 3rd gear shift. i hit 6k rpm at 7-8psi, kicked the clutch pedal in the face as hard as i could, and used all my might to slam the cut stock shifter into third gear.
again, no BOV sound (and no, it's not seized;)) nearly perfect shift! woo! as soon as i hit third gear, i began to re-open the gap that his small t28 turbo was trying desperatly to close at the beginning of the race. (at this point, 2lengths behind me) in third, i was hitting about 10psi, and it crept to 15, luckily. :)
i redlined third gear, kicked it into fourth, and kept pulling, and pulling, and pulling. i hit 100mph, and he was WAY behind me. i shut it down there, and let it coast back to 60mph. by 100mph, i was about 7-8 car lengths ahead of him.
we pulled into a sidestreet, and talked a bit. he was really surprised that my car pulled him as hard as it did. infact, that was the first race he'd ever lost since he did the sr20 DET swap. :) all in all, i'm very proud of my rusty supra. it layed the smack down on a very nice looking/performing nissan sentra ser spec V, with the aforementioned swap.
cliffs: i smoked a SR20 DET swapped nissan sentra SE-R, from a second gear roll to 100mph.
hope you enjoyed!
-shaeff
Wendigo
Ericsplosion
Jul 25, 2005
331
New Paltz NY
VERYNICE!!! It's one thing to win a race, I can beat a honda with my minivan in neutral, but to beat something that nicely worked really says that your blood sweat tears time and money are worth something. Plus it sounds like your technique was perfect. :biglaugh:
kwnate
Lurker
Jul 10, 2005
2,725
None of your fucking business
Nice kill, and your story telling is top noch, It was like I was there :) (I'm not being sarcastic)
shaeff
11
Around
aw. thanks guys! :) i dont post my day to day kills, (or weekend kills i should say) as they're never anything special. but when i come across something that has work done to it, i get really excited. this was a long-anticipated race, and i went home victorious. it still makes me feel good!
thanks for the kind words:)
-shaeff
shaeff
11
Around
so, apparently, next time i meet my friend, (sean) he's going to have "more" done to the car....
but so will i. ;)
-shaeff
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
That's a good kill, bet he was shocked. Great story telling too, It understood every bit and it was fun to read. Most stories are huge run on sentences that jump around and I have to stop reading and just skim to see who won.
shaeff
11
Around
thanks guys. :) i just bought a greddy profec B electronic boost controller from garagefugimoto. so i should build boost even more quickly now, thus pulling away even harder. :) i cant wait!
-shaeff
s383mmber1
3,614
Somers New York
That was probably the best kill story to date. Extremely well told Shaeff!!!
By the time i was reading it i was prob close to two inches away from my screen. It was like i was there!
Awesome kill my friend!!!
-William
edit- supramania.....WHY???
"You must spread some Reputation around before giving it to shaeff again."
shaeff
11
Around
haha. thanks, will! :) we gotta meet up sometime soon. it's getting warmer out, and i've got all kinds of goodies going into my car!
-shaeff
s383mmber1
3,614
Somers New York
Hell yea Shaeff! There is a meet coming up real soon, well actually two of them. They always turn out great! Ill let you know! errr ill PM you.
I still have to get my damn lisence and get my car on the road.....
:biglaugh:
May 5th is the big bad road test!
Johnny Dangerously
I can eat planets
Apr 4, 2005
278
Corpus Christi, TX..
great kill shaeff!! its not often you read well written kills, so this one is special :)
your boost creep is a definate reaction to your DDP...i had the same issue..i didnt ilke the noise nor did i care for the boost creep..so i traded the DDP for a Suprasport DP. :)
main remedy is to port the wastegate port..should be good to go after that :).
great written kill.
shaeff
11
Around
thanks johnny. :) i don't mind the noise, and i won't mind even more when i get my EBC hooked up, as it'll only be wicked loud at WOT. after i get a turbo upgrade, i'll probably port the wastegate a bit. thanks for the suggestion.
-shaeff
miggles
i wasnt speeding officer
Jun 3, 2005
526
perth West Australia
wikkd kill dude, though you should have kicked the clutch like your kicking a bully in the shins or a mugger in the nuts :biglaugh:
you have a way with words dude, well written. Bring on the next kill stories :naughty:
shaeff
11
Around
haha. thanks again, fellas. :) i might have a few more this after this weekend. my girlfriend is going away so i'm going to play around a bit. :)
-shaeff
