sqeak in the front of the car
supradjza80
Mr. Formula SAE
Apr 24, 2007
782
Appleton, WI
www.uwracing.com
I have been trying to figure out what is sqeaking in the front of my car. The squeak occurs when going in and out of drive ways (wheels turned or straight) and the same squeak occurs when getting on the brakes (I only notice this at low speeds and light braking). So I parked the car and opened the hood with the wheels completely straight. I started pushing on the car, jouncing the suspension, and no squeak. So then I turn my wheels close to full lock but not all the way (so it does not hit the steering stops as they will obviously make noise). And sure enough I get the same squeak from both the left and right side when i jounce that particular side. I am not sure where to look or what to lubricate etc.
I would think its bushings, but the bushings should squeak with the wheels straight as well. I was thinking about spraying the bushings (upper and lower A-arms as well as the ARB) with silicone lubricant but I dont want to spray things unneccasarily.
After searching around I couldnt find a post that seemed to describe what i am talking about. Hopefully somebody may know. As for background on the car it is a 92 with 88,800 on the clock, the car handles perfectly - so i suspect the bushings may be old but definitely not worn out.
Any help is appreciated.
Thanks,
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
When you turn the wheels it changes the angle the weight is loaded onto the controll arm bushings. which could result in a squeek only at certain steering angles. So I believe it could be a bushing that may not be totally gone yet and only shows the wear (in the form of a squeek) at or near steering lock left, or right, or both.
