Okay I realize I'm a noob... but I've searched and searched, even talked to DrJonez and Jeff Lee... and both are starting to run out of ideas.
To be as thorough(sp?) as possible, I started out replacing all the stock clamps on the intercooler pipes as the one that goes from the turbo to the IC wasn't tighening anymore. While I was at it, I inspected the pipes also. My power steering and a/c were leaking, I don't use either, so I cut off the belts. I put the IC pipes back, went to start it, and it wouldn't idle worth crap, and couldn't rev past like 2500rpms w/o shooting mad flames out the exhaust. I consulted with a couple people.. they mentioned timing, and it was, magically it jumped... I reset the timing, with the terminals jumpered, and set it to 10-11 degrees. Idled perfectly afterwards... but I couldn't rev past like 2500-3000 in the boost range(anything after 1psi, while driving). I ended up changing to new plugs(NGK's, gapped to 0.30 or 0.8mm) Tried different AFM's, coil packs. I'm running open turbo elbow due to someone using my exhaust and crushing it. Also using a Tial BOV. I recently did a KS rewire, so there's not a SINGLE code popping up, as that was the only one.
I forgot to mention that I can rev ALL I want in neutral.
I do have two vids. I will post links to them. The vids explain best what is happening.
Thanks in advance guys!! I know we can get to the bottom of this:icon_bigg
http://www.zippyvideos.com/1330931296229236/mov05775/ -- revving freely in neutral
