So recently my car has been sputtering or cutting out alittle at anything over 15psi. At first it wasnt bad, it was more of a poping sound than a power loss. Then it got worse and almost sounded like hitting rev limiter and had a slight power loss. I figured it might be some bad spark plugs so i got some new autolite 3923's and put them in. However, it only helped alittle, the sputting still occurs at 15+psi. If i run under 15psi it runs very smoothly. Any idea what else could cause this issue? AFR reads 11.5 at WOT.
My second issue is with my profec B electronic boost controller. I just installed it today. The issue is through 1st 2nd 3rd and 4th gear it the car over boosts and wont go by what i have the Profec B set at, however, in 5th gear it works perfectly and will hold low boost throughout the gear. Its almost like in lower gears it just boosts to fast and just doesnt open the wastegate up. And this is even with the Balance control set to sharp all the way. any ideas on this problem?
