mirage83;1342801 said:A spun bearing may have done some damage to the crank, but nothing that's not fixable by doing a regular inspection and at least a partial rebuild on the bottom of the engine. Unless something else cut loose in there, you're not in too bad shape.
tbcmorris;1344844 said:^^^^^^^^my thoughts exactly
What the hell needs to be welded????
That being said id buy it....cranks can be fixed by being ground and then running and oversize bearing.
IJ.;1344893 said:Only down to a 10 thou cut then you have to niteride them as the stock induction hardening isn't very deep.
