I am unsure about any of the old school modded ECU's. Mines and Techtom both did them, but if I remember right, they were for the stock setup The lex/550 trick still requires a piggyback to fine-tune it as far as I know.
As for the pins, which ones did you need? If you're trying to re-pin the old and new style injector clips- it won't work
I tried, they use a different holding fixture within the connector. Only 2 options are to splice in new pigtails that fit the new injectors, or make jumper harnesses that plug into the stock connectors and have the right style connector at the other end. I've seen some really nice jumpers on here...
