Spray Painting the moldings?
DonS1mpson
Black Supramacist.
Mar 19, 2006
674
England!
Can someone get me the trim code for a car with black mouldings?
Apparently there are loads of different styles out there, but I'd need a code to order a set.
Thanks
Josh
ValgeKotkas
2,224
Over the pond
Узнать цену... 75732-14200-02 01 08/1990 - 08/1991 GA70,JZA70..WIB;RED MICA,3H8
Узнать цену... 75732-14200-12 01 08/1991 - 05/1993 GA70,JZA70..WIB;SUPER RED 2,3E5
Узнать цену... 75732-14200-24 01 08/1990 - 05/1993 GA70,JZA70..WIB;BLUE M.,8J3
Узнать цену... 75732-14200-53 01 08/1990 - 05/1993 GA70,JZA70..WIB..(GTT,GTL);DARK GRAY,182 ,202
Узнать цену... 75732-14200-H0 01 08/1991 - 05/1993 GA70,JZA70..WIB;MEDIUM TORQUOISE M.,749
Узнать цену... 75732-14221-18 01 08/1990 - 05/1993 GA70,JZA70..WIB;ОЬ-Д КЯВ№--Ю,SUPER WHITE 4,050
Узнать цену... 75732-14230-03 01 08/1990 - 08/1991 JZA70..GTL;SUPER SILVER 3 M.,051
That's what's the parts list gives....
p5150
ASE and FAA A&P Certified
Central Idaho
or you could not be too chincy and purchase a gravity feed spray gun from harbor freight and some real automotive paint at a paint store. The whole setup would probably cost around 100 bucks and work better, look better and last longer.
DonS1mpson
Black Supramacist.
Mar 19, 2006
674
England!
Thanks for the paints tips guys, but I almost certainly want to go with black 89+ mouldinginstead of going through all the hassle of painting my current ones.
I just need the correct trim code now
YouGotSpooled
290
Saskatoon, Sk. Canada
I would also recoment having a shop do it.
But...if you are on a budget, and you want it to last and look decent....get some plastic prep and clean all the moldings, sand them a bit with 400 grit sand paper, then clean them again. Go to the auto parts store and look for black bumper and trim paint. It is made to stick to plastic and rubber trim and it more flexable then normal spray paint. Do many light coats instead of trying to fully cover it all at once. Also make sure you tape off and use newspaper to protect the rest of the car from overspray.
Huh.. didnt I say the exact same thing pretty much..? Lol..
