OK, so this weekend i took apart my dash and took out the gauges to put on new faces. The oil gauge came apart instantly and broke as i took it out. ( I'm not bothered, it never really showed much help, especially that my 87 is N/A so i don't mind the gauge not working. So I put the dash back together, and all the gauges work as they should (besides oil) And now my speedometer wont work. i drove it up and down the road a few times, and the needle just wont move. i think i may have broke the speedometer cable/connector? (If i did, i don't mind, it will be old anyways a new one would be nice just for the sense of things). Or maybe i am not lining up the back of the gauges with the cable in the back of the dash? I really am clueless here. If anyone can tell if its broken/needs to be lined up exactly, that would be immensely helpful. It worked perfectly fine before i took out the gauges, so i don't think it is a problem with being connected under the car.
At this point I don't really know what to do to fix it. I've taken out the panel and placed it back in around 5 times now, maybe i was missing the needle or something?
But it did not work a single time. just going to unhook everything and wait for my cousin to stop by, if that does not work maybe a shop then.
Maybe one of you guys know what i'm doing wrong and i can fix it in a matter of minutes? Thanks.
