speedometer cable to electronic sensor what do i need?
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,966
The elbow off the tranny keeps breaking on my car. Those bitches aren't cheap either. That last brand new one I put in lasted 91 miles before it broke and I installed all new cables with it also. I suspect the heat off the downpipe from the gt35r is killing it.
Orion ZyGarian
Jeff Lange wannabe
Apr 2, 2005
1,490
Sarasota, FLorida
www.suprastore.com
I'm wondering about a solution for this as well. All said and done, an MPH reading shouldnt be too hard to set up, but I'd really like to still have a working odometer, and really dont want to destroy a perfectly good cluster to make space for stuff like this.
I'm tempted to just start something from scratch with a series of gauges. Again, I'd like a working odometer though, preferably a working trip odometer as well. I'm not scared of a fancy setup like an iQ3, but I dont care for how it looks personally.
How does the digidash keep track of that stuff? I'd love an all digital dash (minus a digital tach), but not crazy about converting a rare RHD piece over with the "wrong" gauge placement comparatively.
Enraged
A HG job took HOW long??
24
Victoria, BC, Canada
if you are cooking them with heat from the downpipe, maybe you should consider using some sort of heat protection. You can get "cool tube" in various sizes to cover the speedo cable, or you could wrap your downpipe with a variety of materials. Not sure why you would continually replace the speedo cable rather that fix the cause...
gtsfirefighter
Sep 26, 2006
2,966
Replaced the first elbow with a used one and it lasted a couple of days. Was told if both cable were bad it could be putting too much tension on the cable inside the elbow. That's when I replaced everything, both cables and the elbow and wrapped that section of the downpipe and cable with a heat wrap. That elbow lasted 91 miles. I have not since bought another and will not until I resolve the heat issue so I'm not continuously buying parts.
1986.5supra_kid
Rice? No its Corn (E85)
Well it was all used. They felt good too. No needle bounce. But when they were removed and the plastic housing is melted and drooping its obvious that it was heat problem not worn out. The long part was getting cooked by the down pipe and then it would lock up and the short one would try twisting it and tear up.
Now it is routed down the intake side,by the slave,then over the transmission by the shifter to the tail housing.
destrux
1,183
10
PA
There's a really simple solution to this.... get the marlin crawler electronic adapter that fits the trans to give the ECU a speed signal. Then buy an Autometer GPS speedometer and fit it into the stock cluster. They're pretty cool. Gearing and tire changes won't screw up your speed calibration anymore, since it actually uses satellites to read your speed.
1986.5supra_kid
Its would be hard to get picture s of but the best I can explain it that it runs down the firewall on the intake side of the engine/trans then over the trans in the middle and into the trans. Its not kinked. After 3 speedocables that's the least of things I want to work on again
Backlash2032
1,823
Nebraska
The only places I'd be worried about would be where it comes out of thr firewall, and then where it goes into the trans. I'm honestly thinking of routing it down the transmission side of the exhaust, since I've only had issues with the short cable melting..
Sent from my HTC Droid DNA
