I've had this happen. I pulled the gauge and after a little searching I found something had broken between the two. I managed to fix it using parts from another donor that was broken in a different spot.
I can't remember the specifics, but there's a part which disconnects the trip odometer from the main odometer when you press the reset button... that fails and the two remain disconnected.
