spear tire
ians13
537
Jacksonville, fl
what car uses the same bolt patturn as the supra so i can get a small light spare* tire the stock spare* tires is full size and very heavy
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
hahaha. or if you're looking to save on weight, i think the front wheel off of a bigwheels should fit quite nicely. as for the bolt pattern, its make-your-own.
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
yeah, um, the spare tire is big for a reason. We have a chunky car and a lil donut wont do much good. Not to mention if you have an LSD, and you run a lil donut on the rear with something big on the other side, you're going to burn up the lsd clutches pretty quickly. Our weight distribution is 55/45, why ruin it by taking weight out of the back? If you want to save 10 lbs or so, lose it in the middle of the car, aka stop eating so much.
ians13
537
Jacksonville, fl
i see i did not know about the lsd thing, i would hate to kill my lsd. did not all turbos come with lsd.
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
is that how it goes? turbos have a lsd?cuz i was curious and never knew...
for that spare tire thing...you can always get a later model MKIII or MKIV 5 spoker.
90T04
Tucson, AZ
www.azsupras.com
Im pretty sure the RX7's that the donuts came with have LSD's too, right?
Edit: Yep they did
your mom said:
In 1984 a more powerful 1.3 liter rotary engine was introduced, the 13B. The 13B produced 135 horsepower and was placed in the 'special edition' cars called the GSL-SE. The GSL-SE were given disc brakes on all four corners and a Limited Slip Differential. The zero to sixty time improved to just under nine seconds.
