Be advised the Autolite 3923 plugs are 1/8" shorter than stock length on the ceramic side. Some folks have experienced a light misfire at low rpm (I did) due to the plug wire boots not fully seating on the plug. It causes arcing.
jdub said:If you installed Autolite 5503 plugs, they are the stock height.
Well, I changed my plugs among other numerous tune ups this weekend. I went with the 3923s (I was running NGK coppers prior), and noticed they were shorter. I'm getting the misfire (around 300-600RPM, when I was doing consistent 700-800s with the NGK), and when I downshift coming to a stop, or go in neutral my RPM drop too low and the car cuts off.jdub said:Be advised the Autolite 3923 plugs are 1/8" shorter than stock length on the ceramic side. Some folks have experienced a light misfire at low rpm (I did) due to the plug wire boots not fully seating on the plug. It causes arcing.
