tlo86;1220441 said:use coppers
i think the 6097s are copper but i want to know if they are cold enough for boost and nitrious, i was also thinking about the 3330s
86_sports_1jz;1221479 said:i think the 6097s are copper but i want to know if they are cold enough for boost and nitrious, i was also thinking about the 3330s
suprahero;1222107 said:At what boost are you hitting it? What's your fuel pressure set at?
gnarkill87;1222447 said:this is what has been confusing me since ive had the car, the car is bone stock no boost controller or anything just dp and catback (3in). The car is hitting 15psi and then cutting out. i had put the silencer in before and it stopped cutting out (this was before i changed my spark plugs) now even with the silencer in its cutting out.
suprahero;1224125 said:Yeah the downpipe and 3" exhaust lets the turbo flow a little more I guess. I've heard of other people hitting fuel cut when they've installed a BIC DDP.
You're hitting fuel cut and not just the plugs breaking up though, right?
I woldn't want to hit much more than 15psi though. You may want to get a manual boost controller and set it at 15psi and be done with it until you do some more upgrades.
