sourcing 89+ knock sensor connector
suprabee
Celicasupra.com Member
May 18, 2006
117
Scotts Valley, California
The rear knock sensor wire broke off and the connector fell apart when I removed it from the sensor (the rear one near the starter). Has anyone found a source for a new connector (this would be for 89+, so the gray square type)? I've read several of the "Knock sensor rewire" threads that some reference the earlier years round connector (82219-89103), but at this point my searching has not come up with a number for the gray square type connector.
rick
suprabee
May 18, 2006
117
30 minutes after my first post above...
Well. I have answered my own post here, and just found a very informative thread on supraforums, that directed me to the correct part. This connector can be found on a sub harness for the p/u and 4runner V6 knock sensor. The Toyota part number is 82219-35010. Available from Toyota, ebay, Amazon, from $13 to $29.
Or you can also just get the bare connector 90980-11166 from toyota for $8.
Piratetip
Far From Maddening Crowds
1,177
69
MKE, WI
Or get it direct from a connector supplier.
Mfr: OEM Yazaki
Series: 090II Sealed Series
OEM P/N: 7283-1015-10
Bru
82
Tampa Bay Area
Just a word of caution. If you ever remove the starter, be careful not to snap off the knock sensor plastic that protrudes from the metal base. I've done this and from now on I use a U joint socket adapter to give me some flexibility in avoiding repeating this mistake. The other option would be to remove the knock sensor first, but that's a pain as well.
suprabee
May 18, 2006
117
I think that the issue you describe with the starter and sensor is on the earlier models. I've removed my starter many times with no issue. I think the older (round sensor) is a bit longer than the later models with the square sensor. Also, I've just learned that this later sensor and connector is also used on the 1j/2jz engines as well.
